Latest: sparrowdclxvi
Overall: 17139
Online Now [320]:
Visitors: 319
Today: 3262
Total: 112391295
Forums › The Car › 206 Problems › whining noise from driveshaft area
tom06
PostPosted: Fri Jan 24, 2014 8:16 am Up
hi newbie here
got a whining noise from os driveshaft area well a granting noise aswell been like this for two or three months but now its a rubber burning smell after a few miles noise there if clutch in or coasting, knocking worsen when cornering wheel bearings are fine,cv joints seem fine iam at a loss the noise seems more in the centre near the intermediate bearing
thanks ian.
PostPosted: Fri Jan 24, 2014 8:30 am Up
Brake pads doing alright?
tom06
PostPosted: Fri Jan 24, 2014 8:34 am Up
yes there fine newish pads and disc's
the car has started to like hold back like a binding brake but i can asure its not the brakes
mattymj
PostPosted: Fri Jan 24, 2014 9:21 am Up
Clutch?
PostPosted: Fri Jan 24, 2014 11:08 am Up
Wheel bearing... ?
PostPosted: Fri Jan 24, 2014 12:19 pm Up
More apparent in lower gears?
If it is, probably first motion shaft bearing in the gearbox has gone
tom06
PostPosted: Fri Jan 24, 2014 3:45 pm Up
its there all the time,the worrying thing is the burning smell
DREWDEN
PostPosted: Fri Jan 24, 2014 7:25 pm Up
Check your auxillary belt, if loose, or any pulleys going bad.
206 2ltr Hdi glx 53 plate
