Latest: airmastertapes
Overall: 17133
Online Now [290]:
Visitors: 289
Today: 119462
Total: 106653039
Forums › The Car › 206 Problems › What/Why Is This Noise
justh
PostPosted: Tue Jan 28, 2014 12:58 pm Up
Can someone please advise what this noise is?
http://www.youtube.com/watch?v=hdtY4GsXV-A&feature=youtu.be
In the video revs are below 2000.
I have been told it is the bearings in the alternator.
Yes I know it sounds terrible.
Thanks in advance.
PostPosted: Tue Jan 28, 2014 1:07 pm Up
Could be...or might be the bearing in the tensioner or even the single pulley.
Best thing to do is to remove the belt and spin all the tensioners and bearings by hand. Any looseness or roughness is likely to be the source of the problem.
DREWDEN
PostPosted: Wed Jan 29, 2014 6:48 am Up
I had this noise, but not as bad, mine was a simple belt replacement.
I started the car up with the belt off, the noise had gone,(confirmation) so i proceeded to just replace the belt, and bingo no noise since.
Worth a try if you want to keep costs to a minimum.
I also was convinced it was pulleys, tensioner.
206 2ltr Hdi glx 53 plate
justh
PostPosted: Sun Feb 09, 2014 11:47 am Up
Thanks for the info.
It was the altinator and the bairings in the tensioner.
rict1883
PostPosted: Sun Mar 16, 2014 11:54 am Up
I have the same noise, was told it was the power steering pump, now after changing and still making that noise Sad
how hard is it to do the tension er? is it recomeneded new or would a parts from a scrappy be ok
macj
PostPosted: Sun Mar 16, 2014 11:57 am Up
Nuy new or buy someones old problem..... easier to fit a new one as its locked.
rict1883
PostPosted: Sun Mar 16, 2014 1:44 pm Up
are any special tools required to change it
