Latest: TigerHunters
Overall: 17144
Online Now [45]:
Visitors: 44
Today: 38678
Total: 115869785
Forums › The Car › 206 Problems › Lots of water under back seats.
devildriverxii
PostPosted: Tue Jan 28, 2014 12:08 pm Up
I did search, found many threads about water in various places, but none under back seats.
I was just wondering what could be causing this? or most likely to be so I can sort it out.
there was a fair bit, not just damp, no where else in the car is wet, no seats, nothing else seems to be affected at all except under both back seats.
Any ideas.
Thanks for advance for the help.
2002 1.6 5dr Black Edition.
PostPosted: Tue Jan 28, 2014 12:41 pm Up
Well since you are driving a 5dr like mine,I had this issue before,and the cause of this problem was having the rear windows slightly open,and the rear lights need to be checked if they are not tight enough,that will allow water to get inside.
robb
PostPosted: Tue Jan 28, 2014 3:51 pm Up
Are you sure nothing in the boot is wet?
devildriverxii
PostPosted: Tue Jan 28, 2014 5:49 pm Up
If the back windows were open slightly then wouldn't the seats be wet?
I'll check the back lights tomorrow as well.
PostPosted: Wed Jan 29, 2014 1:04 pm Up
slightly open does not mean wet seats ;),a small crack can do wonders..lol
PostPosted: Wed Jan 29, 2014 2:58 pm Up
Check the ring on the fuel pump is done up tight.
gpvecchi
If boot is wet too, water will come in from the rear right tail light. I had some liters of water under my back seat...
Just put a ring of adhesive foam where the tail light seal lean to the chassis
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Alex206
PostPosted: Wed Jan 29, 2014 4:46 pm Up
i had this problem, both spare from scrapy Wink
DREWDEN
PostPosted: Wed Jan 29, 2014 5:24 pm Up
Simple realy, next time it rains, take everything out of the boot, lift the rear seats up, watch and see which direction and area it is coming from.
206 2ltr Hdi glx 53 plate
PostPosted: Wed Jan 29, 2014 5:32 pm Up
Unless it's coming from underneath when he's driving.
123nathan0g
PostPosted: Wed Jan 29, 2014 5:42 pm Up
I had a similar problem, I took the rear seats about 3 months ago and noticed water, however my boot and seats are dry, I can only assume its coming from under the car, however I haven't had the seats out since to check.
commandosqueak
PostPosted: Thu Jan 30, 2014 10:38 am Up
There are grommets/plastic clips in the boot the water is most likely coming in there. take them out put in a bit of sealent or rubber oring and pop them back in. should solve the problem
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
devildriverxii
PostPosted: Sun Feb 02, 2014 12:56 pm Up
Thanks for the help, hopefully I'll get this sorted Smile
