Latest: Puggingalong
Overall: 17129
Online Now [296]:
Visitors: 295
Today: 30363
Total: 101070207
Forums › The Car › 206 Problems › leak on head gasket
leak on head gasket
kickingkay01
PostPosted: Tue Feb 25, 2014 6:53 am Up
AGH!!! ok my 206 is currently in the peugeot garage had a faulty airbag light....however they have informed me that there is a tiny leak on the head gasket which will cost me £800 on top of the £500 for the other work Sad the car runs fine but has always hated traffic jams ive had it for 3 years now.... im asking for advice is the price likely to be cheaper else where or should i risk it til it actually goes...its 06 plate and only done 56k...i was thinking of selling it before it went into the garage and not planning on spending £1300!!!
billo3000
PostPosted: Tue Feb 25, 2014 9:40 am Up
Put it this way. I had an mg zr before i bought my gti and that was £350 with a mobile mechanic (but done it myself for £50), I HIGHLY doubt doing it on a 206 would be any different. I think they are taking the p**s at that price mate
kickingkay01
PostPosted: Tue Feb 25, 2014 10:20 am Up
thank you so much for your rely Smile i know they can be dearer than most garages but i have had some really bad "repairs" done previously at my local ones which have ended up costing more..but i wont be paying peugeot for this one lol
cheers
PostPosted: Tue Feb 25, 2014 11:26 am Up
There are loads of decent independent garages out there. Peugeot dealers don't make sense for any car that's under warranty still.
PostPosted: Tue Feb 25, 2014 11:29 am Up
It will be a headgasket oil leak. Its very very common, and I wouldnt worry about it if I was you
kickingkay01
PostPosted: Tue Feb 25, 2014 12:32 pm Up
thanks all....the service guy checked value and he thinks between 2-2.5k so it cant be too bad ;-!
copey
PostPosted: Wed Feb 26, 2014 1:57 am Up
8ton for a head gasket? did you get free lube for when they bummed you
02 2.0 hdi d turbo
gizmothedog
PostPosted: Thu Feb 27, 2014 1:16 pm Up
I would try a bottle of "steelseal" first.
My dad used it in a golf and it worked.
£30 with a money back guarantee?
