Latest: tbafonso
Overall: 17130
Online Now [234]:
Visitors: 233
Today: 84230
Total: 103445483
Forums › The Car › 206 Problems › Need an answer ASAP. Height of 180 rear suspension
uttz
PostPosted: Sat Feb 08, 2014 1:13 pm Up
Want to set my rear suspension back to stock height what's the measurement from the chassis to the arm or even the attachment point to the arm
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
PostPosted: Sat Feb 08, 2014 1:32 pm Up
Height between the ground and the rear jacking point on the sill should be 133mm (+14mm, -11mm)
uttz
PostPosted: Sat Feb 08, 2014 7:21 pm Up
well the suspension is off the car.. so need a measure of the arm to body so that i can get a correct height
uttz
PostPosted: Sat Feb 08, 2014 8:44 pm Up
how to set up original ride height?
uttz
PostPosted: Sun Feb 09, 2014 2:11 am Up
the dummy damper length would work too
