Latest: tbafonso
Overall: 17130
Online Now [304]:
Visitors: 304
Today: 47359
Total: 104579125
Forums › The Car › 206 Problems › 206 morette headlights
gogs_macaulay
PostPosted: Mon Feb 24, 2014 2:19 pm Up
could someone have a look at these
they have been removed from a ph1 h4 206. will they fit my Gti180. will i need to mod anything to get them to work?
PostPosted: Mon Feb 24, 2014 3:26 pm Up
Have a look at mine that I fitted this week mate, in the first pic there is a brown wire, thats your earth which should have an m6 lug on it, you'll notice that the h7 adaptor is the black block with 3 spade like black shapes going into it with the main headlight wiring going off to the right
In the second pic there is a smooth shape black cable, thats the fuse box wire, I had to fit a fuse to this cable before securing it to the bolt which you'll see when you take the cover off, think i used a 13mm lug and a spare nut to secure it
iainlovatt
PostPosted: Mon Feb 24, 2014 3:40 pm Up
Direct fit, see the grey female block, that's the h7 adapter that allows you to put the morettes on your car. They are not h4 due to that!
(My Garage)
Targa180
PostPosted: Mon Feb 24, 2014 4:54 pm Up
I second that motion
