Latest: tbafonso
Overall: 17130
Online Now [227]:
Visitors: 226
Today: 2156
Total: 103793727
Forums › The Car › 206 Problems › my new 206 problems
my new 206 problems
ash5
PostPosted: Mon Feb 10, 2014 2:39 pm Up
I have just bought a 206 after owning Vauxhalls for the last few years, just noticed a few problems with it. first problem is the there is a rattle, banging sound coming from the front when turning. the second problem is every time I brake there's a hissing sound coming from the passenger foot well. do any of you lot no what they could be.
thanks
Phil74
PostPosted: Mon Feb 10, 2014 4:28 pm Up
Banging sounds like drop links I had mine done very cheap and you could do it yourself. Hissing might be a snake under the footwell mat.. Can't help on that one mate
Seatock789
PostPosted: Tue Feb 11, 2014 9:45 am Up
The banging could be any number of things. Drop links are probably the cheapest and easiest to replace, ARB bushes could be on their way out - another easy & cheap job. Other things that could be causing the banging - Top suspension bearings, broken spring & driveshaft. Unfortunately there is no easy way apart from pulling everything apart to find out what's causing it.
If it's any consolation, I've had the same issue for a few months so it can't be serious.
As for the hissing, again could be any number of things, I'm thinking air con leak? Radiator leak?. Get a mate to put his foot on the brake and see if you can get a more precise location.
ash5
PostPosted: Tue Feb 11, 2014 12:58 pm Up
just had a look on google and it looks like the hissing could be the break servo
thanks for the replies
