Latest: sparrowdclxvi
Overall: 17139
Online Now [100]:
Visitors: 99
Today: 12779
Total: 113540468
Forums › The Car › 206 Problems › Injectors
Injectors
Deano
PostPosted: Fri Feb 14, 2014 10:12 am Up
Hi everyone not been on for a while because my O2 206 140 has been behaving its self now I was driving along the other day the computer said 50 miles left and needle was just above last two lines when all of a sudden it ran out any got some petrol put that in needed towing off but then realise it was misfiring so checked plugs all ok coil pack had just been changed not long back so I took wire off number One on injector and it cut out 2n3 kept running n 4 cut out so which ones are the faulty injectors if anyone could help much appreciated or ye I done a compression test and all ok thanks
PostPosted: Fri Feb 14, 2014 10:19 am Up
Have you had the codes read to see if anything comes up?
If you ran out of fuel, it's easy to pick a bit of crap up from the bottom of the tank.
DREWDEN
PostPosted: Sat Feb 15, 2014 9:55 am Up
Pulling the wires off the injectors will have registered a code, so if you go for a diagnostics check inform them of this.
206 2ltr Hdi glx 53 plate
Deano
PostPosted: Sun Feb 16, 2014 11:55 am Up
So does anyone know which ones are the clogged injectorsd is it the ones that cut out
PostPosted: Sun Feb 16, 2014 2:09 pm Up
No - the blocked ones are the ones that keep firing. isn't that obvious.
Yes I am tired and cranky. Yes the above is taking the p**s.
For info, if you are looking for a misfire buy one of these:-
www.ebay.co.uk/itm/Non...1c37bdaef9
The misfiring cylinder will have a cooler exhaust manifold temp.
Deano
PostPosted: Tue Feb 18, 2014 12:49 pm Up
Well don't take ya crankyness out on me
Deano
PostPosted: Tue Mar 04, 2014 9:31 am Up
This is a funny one because put a bit of cleaner in and battery died one day so got bumped off all of a sudden the car starts running right now am not sure if my petrol gauge is working because ran out of petrol again said it had quarter tank got bumped it started this misfire again so went to scrap yard heard the engine running so I took the full rail put it on stilll no diffrence when I take the two end one off it's still runs when I take the middle two wires off it stalls so is it some thing further back on the two wires u think
PostPosted: Wed Mar 05, 2014 10:14 am Up
To cranky to reply Smile
PostPosted: Wed Mar 05, 2014 10:18 am Up
Which one is you?
