Latest: Beduff1977
Overall: 17134
Online Now [105]:
Visitors: 104
Today: 58729
Total: 107164107
Forums › The Car › 206 Talk › hi all new here and need info
sparkey
PostPosted: Fri Feb 14, 2014 5:06 pm Up
Hi the I have just got a 1.4 206 and I found out the clutch was slipping I done what you have to do to see if it is slipping and all is ok only slips when I drive the car but today I went out in it and I just pulled the clutch pedal up and it stoped the slipping how can I fund out if I need a new clutch cable the car is going for an mot 2 most morning any info would help thanks all.
LiamMiller
PostPosted: Fri Feb 14, 2014 7:58 pm Up
Clutch could be getting too hot, I had the same problem on my old 206, just ask your mechanic at the garage tomorrow see what he says
sparkey
PostPosted: Sat Feb 15, 2014 8:56 am Up
Been to mot and it passed so one happy man he had a look at the clutch and he took it for a drive and sods law it didn't slip at all so still dont know
macj
PostPosted: Sat Feb 15, 2014 10:05 am Up
problem may be the loose nut behind the steering wheel then.. or if its a cable clutch I would look at the cable. If it stops slipping when you lift the pedal it may be partially seized,,,,, if its a hydraulic clutch then I would opt for lubricating the pedal pivot first.
I am sure someone will come along and tell you which it is... cable or hydraulic
sparkey
PostPosted: Sat Feb 15, 2014 7:12 pm Up
I know it is a cable clutch this is the first time I have had a 206 I normally have fords and can fix them but have no clue on Peugeot s
macj
PostPosted: Sun Feb 16, 2014 4:10 am Up
does the cable creak or appear stiff in operation.... my suggestion... try a new cable first. its the cheapest solution first
PostPosted: Sun Feb 16, 2014 7:13 am Up
Ye, auto-adjusting cable would be highly likely.
