Latest: Stu-mill
Overall: 17131
Online Now [57]:
Visitors: 57
Today: 12568
Total: 104802002
Forums › The Car › 206 Problems › Peugeot 206 back washers issue
nottingham123
PostPosted: Mon Feb 24, 2014 4:06 am Up
Hi
peugeot 206 1.4 GLX back washers dont work? i can activate my wiper however when i try to effectively wash the back window you can hear the motor but no wash comes out?
Can some advise on if this is a problem or how to fix this.
PostPosted: Mon Feb 24, 2014 4:22 am Up
If the pump is working, I'd look at the washer fluid reservoir being empty. break in the pipe or a blockage somewhere, possibly on the 3rd brake light where the water comes out.
nottingham123
PostPosted: Mon Feb 24, 2014 4:32 am Up
I have a distinct feeling that the boot or wiper may have been changed as i cant even see where the washers are located.
PostPosted: Mon Feb 24, 2014 5:45 am Up
There should be a tiny jet in the middle of the 3rd brake light
nottingham123
PostPosted: Mon Feb 24, 2014 5:49 am Up
Brilliant i will check once i look at my car later
If there is a blockage will i have to put a pin through?
