Latest: airmastertapes
Overall: 17133
Online Now [94]:
Visitors: 93
Today: 6211
Total: 106670469
Forums › The Car › 206 Talk › Original Factory Mats
PostPosted: Mon Feb 17, 2014 3:12 pm Up
Unfortunately my 206 came with tattered non factory mats, due to the bolt holders for the original mats being broken off.
Wanting to get factory mats but they'll have the holes for securing them and I don't want to use velcro, is it possible to still get the securing bolts/clips?
PostPosted: Mon Feb 17, 2014 3:19 pm Up
well you can always think of a replacement for the whole floor carpet with one got none broken ones,as it's fairly a simple DIY job.
PostPosted: Mon Feb 17, 2014 3:29 pm Up
The screws that hold the mats are fairly standard parts, they just screw into the carpet. Peugeot dealer will do them.
PostPosted: Mon Feb 17, 2014 5:57 pm Up
Mat mounting kit (8) is £4.49 (7585V4)
Retaining clip RC (11)£0.52 (7584AQ)
Staples kit except RC (72) £1.86 (7583HC)
A velour mat set with fittings is £33.48 and rubber mats £37.81
Danz
PostPosted: Tue Feb 18, 2014 7:21 am Up
Not wishing to hijack this thread but anyone recommend some non OE mats ?
DannyBoy
PostPosted: Tue Feb 18, 2014 8:05 am Up
Ambassador Car Mats
Used them for the last 3 cars I've had.
dsiingh
PostPosted: Thu Feb 20, 2014 6:41 am Up
GSF also do tailored car mats too, iirc they are £25-£34.99, plus if u have gsf discount card you get ten percent off.
Pug 206 1.4 SW - July 2013 - Present
Peugeot 206 1.4 HDI - Oct 2013 - Present
BMW E30 - April 2013 - RIP
Lecktorious
PostPosted: Thu Feb 20, 2014 7:06 am Up
Trade Rating: +59
I've got a set of factory mats from a 180, they are a bit worn but should come up ok with a wash. Drop me a PM if you're interested.
'98 Nile Blue 306 GTi 6
