Online Now [642]:
Visitors: 641
Today: 192937
Total: 145303162
Forums › The Car › 206 Talk › Front suspension
Front suspension
Forum Index › 206 Talk
Tolkienfan001
PostPosted: Sun Mar 09, 2014 8:31 am Up
Trade Rating: +13
So the car has just hit 75k. The front suspension is looking a little tired. And starting to get some creaking and knocking.
I am planning on replacing the;
Top mounts
Shocks
Springs
Lower arms
Drop links
I will then get the tracking done etc.
Any advice on the parts above in terms of makes, where to buy? I am happy to get all oem from pug if the price is not too silly.
Also advice on how long it should take two people? And any specifics to look out for?
2005 1.4 16v Sport
Check out my 206 here!
Conners300983
PostPosted: Sun Mar 09, 2014 9:02 am Up
I got a set of skf top mounts from euro car parts that came with bearings for around £60. I know skf will be on par with oem for quality not as sure how the price compares though. Might be a good time to upgrade a few bits if your spending some cash anyways. Maybe a set of eibach springs??
Conners300983
PostPosted: Sun Mar 09, 2014 9:05 am Up
PS it took me a couple of hours to fit coil overs and top mounts, so add maybe an hour or two for the wishbones. Around 4 hours total I'd say. Less if your both good on the spanners.
James3107
PostPosted: Sun Mar 09, 2014 9:06 am Up
Euro Parts have a up to 50% online sale atm so there would probably be your best bet. They're cheap enough without discount so should save a bit.
1.4 HDi Indigo Blue
doski
PostPosted: Sun Mar 09, 2014 9:33 am Up
you might wanna buy a pair of track rod ends while your at it there only around £10 each and you have a good chance of scrapping one when you take them off . did an astra last week and had to hacksaw through them as the bolt was just spinning
SinfulDesignCom
PostPosted: Sun Mar 09, 2014 9:34 am Up
Don't cheap-out on the lower arms! Went through a few myself before finding Lemforder - also from Euro's so hopefully you will get a good deal if discount applies Smile
Eibach and Bilstein for the others - again my opinion through fast road and occasional track use.
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
Tolkienfan001
PostPosted: Sun Mar 09, 2014 11:11 am Up
Trade Rating: +13
Thanks for the advice and opinions. Track rod ends were done last summer. I was looking at euro car parts looking like £300-£400 for all parts. I was looking at lemforder eibach and bilstein. probably go down this road then.
Smile
2005 1.4 16v Sport
