Posted: Mon Feb 24, 2014 4:06 am |
Hi
peugeot 206 1.4 GLX back washers dont work? i can activate my wiper however when i try to effectively wash the back window you can hear the motor but no wash comes out?
Can some advise on if this is a problem or how to fix this.
Posted: Mon Feb 24, 2014 4:22 am |
If the pump is working, I'd look at the washer fluid reservoir being empty. break in the pipe or a blockage somewhere, possibly on the 3rd brake light where the water comes out.
Posted: Mon Feb 24, 2014 4:32 am |
I have a distinct feeling that the boot or wiper may have been changed as i cant even see where the washers are located.
Posted: Mon Feb 24, 2014 5:45 am |
nottingham123 wrote: |
I have a distinct feeling that the boot or wiper may have been changed as i cant even see where the washers are located. |
There should be a tiny jet in the middle of the 3rd brake light
Posted: Mon Feb 24, 2014 5:49 am |
Brilliant i will check once i look at my car later
If there is a blockage will i have to put a pin through?
