Latest: tbafonso
Overall: 17130
Online Now [123]:
Visitors: 122
Today: 28350
Total: 102188280
Forums › The Car › 206 Problems › Missing head bolts
Missing head bolts
Majid
PostPosted: Mon Feb 24, 2014 6:51 am Up
Hi
I have noticed my engine block meant to have 8 head bolts but there are 2 missing.
What damage will this cause?
i.imgur.com/KhxheXW.jpg
i.imgur.com/jcHdhSX.jpg
Any help will be welcomed.
Peugeot 206, 1.6, 16 valve
2003
gazza82
PostPosted: Mon Feb 24, 2014 7:21 am Up
Don't think they are the head bolts .. they will be under the cam cover ... maybe on different models these hold pipes, cables, etc ...
Majid
PostPosted: Mon Feb 24, 2014 7:56 am Up
But there are four bolts in the bottom
There are two just In The middle
it would be good if someone could upload a pic showing their engine
2003
Conners300983
PostPosted: Mon Feb 24, 2014 8:00 am Up
What He Said they look like threaded holes to attach clips etc too to me. If you look down them is there anything behind them or can you see straight through
kwakzx7r
PostPosted: Mon Feb 24, 2014 8:26 am Up
Way to small to be head bolts plus head bolts bolt into the block and are under the cam covers.
Majid
PostPosted: Mon Feb 24, 2014 8:58 am Up
Hi
Here's a pic of the bottom four bolts
2003
Majid
PostPosted: Mon Feb 24, 2014 9:00 am Up
These bolts ain't for the rocker cover
2003
PostPosted: Mon Feb 24, 2014 1:45 pm Up
Nothing wrong with your engine....all is fine
PostPosted: Mon Feb 24, 2014 1:48 pm Up
If the rocker cover was supposed to bolt onto them it would be sat on them...it isn't.
DanT
PostPosted: Mon Feb 24, 2014 2:43 pm Up
They arent meant to have anything in. My old saxo was the same (j4 engine) whereas yours is the newer jp4 type but it still applies. You have nothing to worry about
Majid
PostPosted: Mon Feb 24, 2014 4:06 pm Up
Thanks a lot guys for your info. Much appreciated
2003
