Latest: Beduff1977
Overall: 17134
Online Now [526]:
Visitors: 525
Today: 132360
Total: 109698978
Forums › The Car › 206 Problems › wishbone
wishbone
gizmothedog
PostPosted: Mon Feb 24, 2014 2:28 pm Up
Hi
has anyone done a wishbone on a 1.4 8v, front n/s?
mot station says they are a nightmare as you have to feed them in a certain direction Confused
got a Haynes manual somewhere....
any experiences?
gizmothedog
PostPosted: Mon Feb 24, 2014 2:30 pm Up
oh, and i've also got a seized brake sensor on the back, apparently you can free them with a bar.....?
RichardEke
PostPosted: Mon Feb 24, 2014 2:35 pm Up
I found these useful:
www.206info.co.uk/Foru...46498.html
www.206info.co.uk/Foru...t=341.html
I found taking the big Torx bolt out, nearest the front bumper, just made it that bit easier to get the ball joint out, using spring compressors would be the best bet though.
Used a 12point spanner on the torx bolts, found it easier.
Lots of topics on this but the 2 links above are the biggest help i think.
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
gizmothedog
PostPosted: Mon Feb 24, 2014 2:36 pm Up
thanks mate
gizmothedog
PostPosted: Mon Feb 24, 2014 2:37 pm Up
links not working mate,
might be my computer though
omega
PostPosted: Mon Feb 24, 2014 3:15 pm Up
hi
did this yester day
dead easy took me about a hour
need hammer. 19mmsocket,12 or 13mm spanner.a 15mm spanner and a pry bar
undo the 2 19mm nuts and take the bolts out from the top,undo pinch bolt on ball joint then pull it out
feed the new one in from the front ,replace bolts then relocate ball joint,this is where you need the bar to pull down so you can get the joint in.
give me a shout if you get stuck
1245678
gizmothedog
PostPosted: Mon Feb 24, 2014 4:00 pm Up
Nice one. Cheers buddy
PostPosted: Tue Feb 25, 2014 7:05 am Up
gizmothedog wrote:
Hi
Find a mechanic / garage that knows what there doing, this lot sound a bunch of idiots if they cant even do a simple 206 wishbone.
gizmothedog
PostPosted: Thu Feb 27, 2014 2:10 pm Up
wishbone all done....
1st one ive done and took me about an hour.
Thanks for your help
gizmothedog
PostPosted: Fri Feb 28, 2014 4:13 pm Up
ive noticed today that the steering is off centre. is this normal after a new wishbone?
Lecktorious
PostPosted: Fri Feb 28, 2014 5:01 pm Up
Trade Rating: +59
You'll need to get your tracking done.
'98 Nile Blue 306 GTi 6
PostPosted: Fri Feb 28, 2014 10:13 pm Up
Find a 4 wheel alignment centre. Don't go to a garage that does tracking using two wheel front only system. The rear is NOT adjustable but there are so many advantages to the 4 wheel system I can't bother listing and explaining here.
