Posted: Sun Feb 09, 2014 2:36 am |
i have a 53 reg 206 and its been fine till january when its started messing about. it cut outs and restarts itself again whilst im driving. this has puzzled my dad who is a mechanic. its been plugged into a diagnostic machine but nothing comes up. any ideas, please help as i cant afford to get a new car.
Posted: Sun Feb 09, 2014 4:13 am |
By cutting out and restarting, I take it you don't mean it dies completely to a stop and then does a Christine and restarts by itself without having to turn the key.
Is there any particular time that it's cutting out, cornering, braking, certain speeds?
I'd start by checking all the electrical connections under the bonnet, including the earthing points. Can't really be of much more help as no idea what engine is in the car or even what fuel it's running on
Posted: Sun Mar 02, 2014 3:09 am |
yes it dies completely and then restarts itself. it tends t do it when slowing down, breaking. but lately its started to die completely and have to turn the key to turn it back on. Again its as im slowing down, breaking, cornering, its started to do it a bit more lately.
its a petrol car and ive recently stopped using supermarket petrol as ive been told that that could be a problem.
i will pass your advice onto my dad. many thanks
Posted: Sun Mar 02, 2014 5:58 am |
Does it cut out when you press the clutch pedal in to change gears, and then restart when the pedal comes back up again?
If so, give this a try: www.206info.co.uk/Foru...c/t=46523/
Posted: Sat Mar 08, 2014 12:07 pm |
thats exactly when it cuts out. brilliant thank you will pass on all advice onto my dad.
Thank you
