Posted: Tue Aug 09, 2011 7:28 am |
Bought my car a while ago, I've always had this plastic broken pipe, with I think/hope is the reasoning for bring up a fault code of P0413.
I'm not exactly what this plastic pipe is/does and where it goes.
Can anybody, especially 180 owners with aftermarket air filters let me know exactly where this pipe goes? And being that I have a cone filter, do I even need to reply my broken plastic pipe? I've got a feeling it would connect down to somewhere of the standard air filter box, of which I obviously don't have..
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Tue Aug 09, 2011 7:42 am |
Oil breather hose.
Posted: Tue Aug 09, 2011 7:46 am |
Thanks! Any idea of where it's suppose to go to?
And I take it, that definitley wouldn't be the reason for code P0413 to be coming up, right?
Posted: Tue Aug 09, 2011 7:48 am |
EuroPeugeot wrote: |
And I take it, that definitley wouldn't be the reason for code P0413 to be coming up, right? |
PM me your chassis number and I'll look it up.
Posted: Tue Aug 09, 2011 9:47 am |
The air pump blows cold air into the airbox that opens a flap a about 3000rpm,
Posted: Wed Aug 10, 2011 1:44 pm |
That's the pipe from air pump to engine head: it blows air into exhaust when engine is cold, to raise cat temperature faster. I don't think it's the cause for P code, if pump is working thera are no more checks... Your P code looks like pump is not blowing: so check fuse, relais and pump itself.
You can disable it in BSI with PPS2000...
Edit: air pump has nothing to do with valve inside air intake: it is moved by a solenoid that bypass or not depressure from intake manifolds...
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Fri Aug 12, 2011 4:50 am |
gpvecchi wrote: |
Edit: air pump has nothing to do with valve inside air intake: it is moved by a solenoid that bypass or not depressure from intake manifolds... |
is there anyway of testing the air intake flap, to check its working?
Posted: Fri Aug 12, 2011 1:45 pm |
sri16v wrote: |
is there anyway of testing the air intake flap, to check its working? |
Mmm... EFI gives solenoid the impulse of opening at about 3/4000 rpms... I assume that if you remove airbox and keep angine at that revs you can see flap opening.
I suggest you to shunt electrovanne to keep flap always open: you'll have a little less linear torque response, but about 0,5kgm more at 3000 and 4000 rpms...
Posted: Fri Mar 07, 2014 11:32 am |
Hi. Just been reading this and wonder if my flap is opening. Is there anyway to test the solenoid?
