Latest: tbafonso
Overall: 17130
Online Now [487]:
Visitors: 486
Today: 14492
Total: 103982432
Forums › The Car › 206 Talk › slackening 180 aux belt
PostPosted: Sun Mar 16, 2014 2:00 pm Up
Got my tensioner etc to do tomorrow, obviously the new one has the locking pin in but whats best way to slacken the old one? Same as it would be any other engine ?(socket on the pully and turn)? Only it looks a bit tight up there to what im used to lol. Wondering if anyone had a trick or anything?
Ben.
PostPosted: Sun Mar 16, 2014 2:26 pm Up
16mm ring spanner will push it out of the way.
DanT
PostPosted: Mon Mar 17, 2014 4:34 am Up
Yeah it is a bit tight up there, i just used one of the Blue Point long reach spanners and it was perfect.
PostPosted: Mon Mar 17, 2014 12:50 pm Up
cheers for replys guys i did see them just as was about to start. Very Happy
releasing the tension wasn't a problem in the end, just getting to one of the bolts i found a bit of git (was hidden by bottom pully) but all done now, no longer sounds like it has a super charger type noise packed under the bonnet lol.
