Latest: airmastertapes
Overall: 17133
Online Now [684]:
Visitors: 683
Today: 65371
Total: 106777236
Forums › The Car › 206 Talk › Indicator position
Indicator position
QuArTz
PostPosted: Wed Mar 19, 2014 4:03 pm Up
Trade Rating: +16
Hi
I want to reposition the indicator.
Is there any law or regulation which states where the side indicator can be positioned?
Hawkers
PostPosted: Wed Mar 19, 2014 4:43 pm Up
This could fail it on MOT. A selector switch missing, insecure, faulty, or not able to be operated from the normal driving position.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
QuArTz
PostPosted: Wed Mar 19, 2014 5:21 pm Up
Trade Rating: +16
Sorry..
I want to move the side repeater bulb.
PostPosted: Thu Mar 20, 2014 3:19 am Up
No more than 2.6 meters from the front of the vehicle (no problem on a 206) and within 40cm from the side.
It must be visible from the rear at a minimum angle of 5 degrees to at least 60 degrees. It should be within 1.5 meters of the ground. If over 75 cm from the ground then it should be visible 15 degrees above and below the horizontal, if lower than 75 cm then visible from 15 degrees above and 5 degrees below the horizontal.
It must be amber in colour, can be of any size and intensity if it is 'e' marked. If not 'e' marked then it must be visible from a reasonable distance.
Simple really. Where were you thinking about putting it?
jbhoy90
PostPosted: Thu Mar 20, 2014 5:15 am Up
bit of a hassle, a mate of mine done it and failed his next mot, though as macca has said keep them within those ranges etc and you should be fine.
out of interest are those kahn alloys you have on?
QuArTz
PostPosted: Thu Mar 20, 2014 2:17 pm Up
Trade Rating: +16
Cheers for the info guys.
I will post up a photo to show the intended area I want to move it to, any input with this would be great.
QuArTz
PostPosted: Thu Mar 20, 2014 2:19 pm Up
Trade Rating: +16
jbhoy90 wrote:
Out of interest are those kahn alloys you have on?
That's my first 206 and yeah, they're 17" Kahn's
jbhoy90
PostPosted: Thu Mar 20, 2014 3:33 pm Up
Thought so, same as mine Very Happy just couldnt see them very well on my mobile, good to see another 206 with them.
jbhoy90
PostPosted: Thu Mar 20, 2014 3:36 pm Up
Not everones cup of tea but i like the wing mirrors with them, my mate removed his indicators and fitted a set and it looks pretty good
QuArTz
PostPosted: Fri Mar 21, 2014 3:16 pm Up
Trade Rating: +16
I am considering modifying a pair of OEM wing mirrors by adding an amber strip of l.e.d's but I'm still not sure if they will look any better than the ones Ive seen for sale online.
jbhoy90
PostPosted: Fri Mar 21, 2014 3:22 pm Up
Hard to say, if done right it could look good, if done wrong could look very tacky, if your thinking of it grab a set from the scrappy and experiment, most youv got to kose that way iaround 15 quid, and you might make 10 of that back if you dont like them and can sell them on Smile
Not sure how they would affect an mot though if you remove the original ones, my nates not had his mot since the change
