Latest: SA01
Overall: 17138
Online Now [214]:
Visitors: 213
Today: 18915
Total: 112188903
Forums › The Car › 206 Talk › Are these Vortex or Chellangers ???
justh
PostPosted: Sat Mar 22, 2014 2:56 pm Up
Hi,
Just a quick question, are these vortex or challengers?
The center doesn't look right but seller has said center is not capped.
Thanks in advance.
[img]
[/img]
kenny16m
PostPosted: Sat Mar 22, 2014 3:29 pm Up
look like 180 vortex
GT Dturbo
Team : Austin Healey Sprite
kenny16m
PostPosted: Sat Mar 22, 2014 3:30 pm Up
the centre badge is normally a chrome lion like a smaller on the boot
GT Dturbo
PostPosted: Sat Mar 22, 2014 4:08 pm Up
They look like they have a centre cap...180 wheels don't. Or do they sometimes?
justh
PostPosted: Sat Mar 22, 2014 4:12 pm Up
I have look at loads on google images and non match these
DanT
The width of the rim will tell you if they are 180 rims or not, think vortex are wider. But from that picture they look like challengers.
Vortex are smooth like so
L5_UKS
PostPosted: Sat Mar 22, 2014 4:14 pm Up
If the centre cap is removable then there challengers, But to me they look like the early vortex's that had a slight lip around the centres but they aren't removable. Then they changed them to smooth centres.
justh
Thats what i thought, he said the are j7
justh
PostPosted: Sat Mar 22, 2014 4:15 pm Up
7j even
justh
PostPosted: Sat Mar 22, 2014 4:18 pm Up
So do you think they are vortex?
Jake86
PostPosted: Sat Mar 22, 2014 4:30 pm Up
Yeah, 7j is the same width as the Vortex. I think Challengers are 6.5. I've seen the early Vortex mentioned - Peugeot were just trying to keep you on your toes!
DSWR
PostPosted: Sat Mar 22, 2014 7:45 pm Up
They don't look like vortex nor challengers. Maybe the earlier Atlantis alloys?? Challengers are 6.5 but have removable centre pieces but those look like a single piece but aren't smoothed like the vortex. Luke maybe right about earlier style ones.
GTi 180 owner!:)
www.facebook.com/notdanwhite
