Latest: morgan20
Overall: 17135
Online Now [654]:
Visitors: 653
Today: 44721
Total: 110596805
Forums › The Car › 206 Problems › intake manifold stuck
tibout
PostPosted: Thu Mar 27, 2014 3:09 pm Up
Hi everyone
new to the forum.
Basically i'm trying to replace the copper washer on my injectors, car is a 1.4 hdi 2003.
My inlet manifold seem to be stuck can't remove it.
Ive remove the 8 bolts on top (the rocker) and the 2 hidden bolts at the back of the inlet. Still i could'not lift it out.
See to be stuck at the back as the front is moving. have i miss any bolts somewhere!! Or is it the intake O ring need a bit of persuasion? I don't want to put excessive force just in case i break something!!
Any help will be much appreciated. Thanking you in advance
Thierry
14hdi
PostPosted: Thu Mar 27, 2014 6:51 pm Up
Did this a while ago on my own car, took two people to pull it off. Just make sure you have every bolt clear before you start pulling.
tibout
PostPosted: Fri Mar 28, 2014 3:16 am Up
Ok thanks for the reply. I have all the bolts off I'm pretty sure there's 10 in total on the intake assembly. I'll give it a go again tonight
