Latest: Puggingalong
Overall: 17129
Online Now [247]:
Visitors: 245
Members: 1
Today: 15397
Total: 100869115
Forums › The Car › 206 Problems › GAUGE WIRING - feed for "lights on"
SinfulDesignCom
PostPosted: Sun Mar 23, 2014 3:12 pm Up
As above - will be wiring in a couple of gauges as soon as time permits. Both need a +12v feed for the illumination - can think of a few, but any that people have used close to the clocks? And best ignition +12v close by?
Cheers
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
PostPosted: Sun Mar 23, 2014 3:25 pm Up
The ashtray sounds a good one I believe.
PostPosted: Sun Mar 23, 2014 3:31 pm Up
Ash tray is definitely the best
SinfulDesignCom
PostPosted: Sun Mar 23, 2014 4:01 pm Up
Ah - didn't think of that one. I was thinking centre console display.
Has anyone wired the earth via the light dimming switch? In theory should work, but we all know how these French love their vehicle electrics Smile
PostPosted: Sun Mar 23, 2014 4:15 pm Up
In theory yes, in practice probably not. The dimmer is built into the clocks so probably runs through the BSI. If you are going to the effort of finding the right wire on the loom, then why not just wire them into the sidelight circuit?
SinfulDesignCom
PostPosted: Sun Mar 23, 2014 4:37 pm Up
Useful info - thank you. Not fussed about the right wire, so ashtray should suffice, and the ignition could come from the radio circuit as it is not used, and would also be fused to protect the gauges.
usher
PostPosted: Mon Mar 24, 2014 1:31 am Up
there is an earth point in the ds footwell by the door at the front
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
SinfulDesignCom
PostPosted: Mon Mar 24, 2014 8:18 am Up
Thanks Usher. That's the first gauge sorted. Just the oil pressure to have fun with. Anyone thoughts on mounting the sensor remotely, or t-piece from the block?
PostPosted: Wed Mar 26, 2014 1:41 pm Up
The oil pressure gauge,you need to replace the one you have,with a sensor give both readings,leveling and pressure,,and use the that for gauge u got
SinfulDesignCom
PostPosted: Wed Mar 26, 2014 3:18 pm Up
I have a t-piece which will screw into the thread where the existing sensor is, from which I can keep both the sensor and the new gauge. I thought it better to have the warning light as a back up to the gauge. After all, a nice bright red LED is easier to see in the case of over-pressure than a short sweep 52mm gauge...
PostPosted: Fri Mar 28, 2014 3:09 am Up
Good thinking,hope you are taking lots of pics,and hope that there will be a how to too Very Happy
SinfulDesignCom
PostPosted: Fri Mar 28, 2014 6:03 am Up
I could be persuaded to do a "how-to" - should really since I have been here for a few years now! An oil pressure could be a bit overwhelming at first, but looks relatively straightforward.
Watch this space... Smile
usher
PostPosted: Fri Mar 28, 2014 12:04 pm Up
i willl be watching for the how to im wanting to ditch everything in the long run and have things simpler
project thread WIP
garage
FAQ
206 gti firedance
SinfulDesignCom
PostPosted: Sat Mar 29, 2014 1:58 pm Up
Well the gauges are done if you have a squizz at my thread. I did take some photos whilst doing it - I just need to fit the OMEX unit and combine it as the wiring is very similar.
Hands cut to sh*t now, but worth it.
