Latest: tebas93089
Overall: 17179
Online Now [113]:
Visitors: 112
Today: 23062
Total: 138216748
Forums › The Car › 206 Problems › 206 automatic 02 plate ESP
Rah1981
PostPosted: Fri Mar 28, 2014 2:06 pm Up
Hi all, wonder if anyone can help?
We have a pug 206 automatic 1.4. When we bought if we knew if had a gear box problem and had the solenoid changed. It used to get stuck in gear and you would have to pull over and turn the car non and off. It used to beep at you to let you know it had happened. Since having the solenoid changed, if started beeping again and we took it back and the guy did a diagnostic but it said unknown code. Took it to a garage today and the diagnostic said 130 electronic stability esp. A that's it. It constantly beeps all the time, every 3-4 minutes. Has anyone else had this problem or could anyone offer any advice?
The solenoid was about £475 to replace. Is their a different type of diagnostic we could have run to find out exactly what the problem is??
Many thanks
Rah
PostPosted: Fri Mar 28, 2014 2:08 pm Up
Has the car actually got ESP fitted?
ESP fault codes & the warning light are known to sometimes get flagged up on a multiplexed 206 without ESP when the battery is on its way out.
Peugeot Planet is what you need to scan / test the car.
Rah1981
PostPosted: Sat Mar 29, 2014 8:05 am Up
what is Peugeot planet?
PostPosted: Sat Mar 29, 2014 8:37 am Up
The dealer level diagnostic software that is best to scan a 206 with.
Rah1981
PostPosted: Sat Mar 29, 2014 8:44 am Up
how can i get this?
PostPosted: Sat Mar 29, 2014 8:58 am Up
Either:
Take it to a Peugeot main dealer for a diagnostic check
OR
Use the forum member map to find someone nearby with Planet
www.206info.co.uk/Foru...55053.html
OR
Look on everyone's favourite online auction site
Rah1981
PostPosted: Sun Mar 30, 2014 10:34 am Up
Thanks very much
