Latest: Kifi69
Overall: 17183
Online Now [1106]:
Visitors: 1105
Today: 12078
Total: 144471923
Forums › The Car › 206 Problems › Seat won't slide?
Seat won't slide?
welsh.Z.S.
PostPosted: Wed Apr 02, 2014 4:10 am Up
Hi all, my passenger seat in my 180 sometimes won't slide back or forwards, anyone had this before and have a solution?
iainlovatt
PostPosted: Wed Apr 02, 2014 4:41 am Up
one of the mechanisms may have gone or not clicked into place. To test this, use the height adjuster and bounce in the chair,
(My Garage)
welsh.Z.S.
PostPosted: Wed Apr 02, 2014 4:12 pm Up
The height adjuster works fine, also the seat tilts ok, just won't slide, I want to take the seat out to have a better look but as the seat is stuck all the way forward I can't access the front 2 torx bolts
206gt160
PostPosted: Wed Apr 02, 2014 4:29 pm Up
A bit of wd40 and a bit of excessive force worked with mine, and by a bit I mean a lot lol
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
welsh.Z.S.
PostPosted: Thu Apr 03, 2014 4:12 am Up
Lol iv gave it a spray, still can't get it to move moved tho
