Online Now [611]:
Visitors: 610
Today: 23060
Total: 145133764
Forums › The Car › 206 Talk › Gearbox issues....
Gearbox issues....
Forum Index › 206 Talk
Ryan324
PostPosted: Tue Apr 08, 2014 9:10 am Up
hi can anyone help...
i have a 1.6 8 valve and when i change from first to second it crunches and its the same when i change from third down to second...
sometimes it wont let me select a gear and i have to literally ram it in
and there's a terrible shake from the right hand driveshaft as i accelerate
now im guessing the gearbox and driveshaft are dead
so whats the best box to put in i want it to accelerate well but not to overrev like hell on a long run just a good medium would be good...
is the 1.6 box the best one to put back in ?
thanks for all help recieved
Ryan324
PostPosted: Tue Apr 08, 2014 9:11 am Up
forgot to mention ive had the wheels balanced and the shake is still there all suspention is tight
so im saying driveshaft but not sure
gazza82
PostPosted: Tue Apr 08, 2014 11:05 am Up
Driveshaft won't affect the gear selection
Clutch adjustment or needs bleeding or clutch is sticking.
Also check the selector rods are moving properly and not loose.
PostPosted: Tue Apr 08, 2014 11:13 am Up
Sounds like a worn input bearing or baulk ring. Just replace the box or get it inspected and refurbished
