Online Now [1077]:
Visitors: 1076
Today: 242884
Total: 146387609
Forums › The Car › 206 Problems › Scraping/crinkling noise from engine?
David1156
PostPosted: Thu Apr 17, 2014 12:59 pm Up
Hi guys, i got back from a drive and noticed a strange noise from the engine when it's idling. It sounds like a scraping noise from the passenger side of the engine. It sounds like it may have something to do with one of the belts but I honestly have no idea. It's a consistent noise.
It's a 1.1 petrol with about 75000 miles and the engine oil level is at the max position on the display. It also hasn't had a timing belt change but I'll be getting that done soon.
Current: Albi Blue Clio 197
PostPosted: Thu Apr 17, 2014 2:50 pm Up
Get a competent friend or mechanic to have a look. If it is a bearing on a belt pulley starting to fail and if it causes the belt to break that is a VERY expensive fix. Get it checked quickly. It might be simple and I have worried you needlessly but it could be about to cost you many hundreds if the belt breaks.
David1156
PostPosted: Thu Apr 17, 2014 2:57 pm Up
I'll definitely be going to a garage tomorrow to see if they can figure it out. I appreciate your help and I understand where you're coming from with getting it checked. Hopefully it'll be something simple but I'm not going to risk not bothering with it, since it could be related to the cambelt and if that goes, I'm in serious trouble.
David1156
PostPosted: Fri Apr 18, 2014 5:42 am Up
The pugs in the garage right now getting a new cambelt kit and water pump. The noise is exactly the same as the one in the video:
youtu.be/WQuIcRQnUss
David1156
PostPosted: Fri Apr 18, 2014 11:47 am Up
Just an update, the noise has reduced, but I've got a new noise coming from the clutch pedal. It's like a grinding/squealing noise that is much louder when the clutch pedal is pressed, but when released, the noise is much quieter. Think I may make a new thread about it.
Think it may be a release bearing in the clutch as I'm guilty of keeping the clutch pressed in at junctions and lights :$
PostPosted: Fri Apr 18, 2014 12:01 pm Up
Perfect way to ruin the clutch Laughing
Wont do the release bearing or pressure plate any good.
David1156
PostPosted: Fri Apr 18, 2014 1:15 pm Up
But I've changed my ways a while ago! Embarassed But seeing as the car has done a fair bit of mileage and i've got a warranty (which'll hopefully covers the cost) it's kind of a good thing, as i'll definitely be keeping the car for a couple of years.
