Latest: tbafonso
Overall: 17130
Online Now [340]:
Visitors: 339
Today: 20288
Total: 103882457
Forums › The Car › 206 Problems › Oil leak possibly caused by head gasket
steveo1259
PostPosted: Mon Apr 21, 2014 2:18 pm Up
Hi Guys,
I have a 206 1.4l 1999 petrol that has done 62000 miles.
It has developed an oil leak from under the bonnet and on closer inspection the leaks appears to be coming from the engine block.
After looking around it appears to be a common fault with the TU engine and requires a head gasket replacement.
How much on average is it for a head gasket replacement with a possible cambelt change at the same time. I want to look around for quotes to get it done but I really dont know where to base my expectations.
Will it cause any damage to leave it how it is? Apart from losing oil obviously?
Owner of 1.4 petrol 206
PostPosted: Mon Apr 21, 2014 2:23 pm Up
Contact Cartoonhead. He's in Manchester area and will give you a competitive quote
www.facebook.com/pages...34?fref=ts
Tolkienfan001
PostPosted: Mon Apr 21, 2014 3:10 pm Up
Trade Rating: +13
I am getting mine done this week
Head gasket with all seals inlet exhaust rocker and head gaskets. Manifold spot welding, head skim, heater matrix pipe and seal change due to leak. Oil pressure sensor, temp sensor. Oil filter oil change, coolant change. Tracking. Cambelt water pump Total inc labour £700.
2005 1.4 16v Sport
Check out my 206 here!
Vexs
PostPosted: Mon Apr 21, 2014 4:04 pm Up
Had my head gasket skimmed and new radiator put in cost me £450
My GTI 180
My Old 1.4 8v
