Latest: sparrowdclxvi
Overall: 17139
Online Now [65]:
Visitors: 64
Today: 10699
Total: 112523446
Forums › The Car › 206 Problems › Front wing replacement
josh206xsi
PostPosted: Wed Apr 23, 2014 6:14 am Up
Hi all, its been a while since I've been on here, but you were all so helpful in the past I thought I'd give it a go.
I have changed the front passenger side wing on my 206, taking the old wing off generally went well (I hit the usual problem of the bolts at the edge of the bumper but eventually got these off)
However when fitting the new wing I cannot for the life of me get the panel gap correct(I had 2days+ of just fiddling in my garage). It seems good at the join to the bonnet and it seems ok to the light at the front, but the edge of the wing to the door sticks out away from the car (the distance from the wing to door is good).
Has anyone else had an issue with the panel gaps when fitting wings and any tips for how to solve this, as the wing has been on the car a few weeks now and its really starting to annoy me.
I should say as well that nothing catches on the wing its just that the rear edge sticks out a little bit.
Thanks in advance for any help, I really hope I get this sorted.
Obsidien black Xsi
alane29
PostPosted: Fri Apr 25, 2014 7:59 am Up
Did u buy a Patent part or a Peugeot genuine part ?
PostPosted: Fri Apr 25, 2014 8:18 am Up
Push the wing in. They bend!
josh206xsi
PostPosted: Tue May 13, 2014 2:50 pm Up
Its a peugeot wing. Ive tried pushing it, it seems fairly solid and don't want to dint it.
Obsidien black Xsi
