Latest: jtq4u
Overall: 17141
Online Now [48]:
Visitors: 47
Today: 31708
Total: 114000708
Forums › The Car › 206 Problems › Engine manigement light
ash5
PostPosted: Sat Apr 26, 2014 4:36 pm Up
How do I turn the engine manigement light off I have fix the problem but the light is still on
PostPosted: Sat Apr 26, 2014 4:56 pm Up
Clear the codes using a code reader
craig1983
PostPosted: Sat Apr 26, 2014 11:48 pm Up
I used a code reader not an expensive one, done the job it also took the service light off
ash5
PostPosted: Sun Apr 27, 2014 1:12 am Up
Cannot just get a cheap universal one or does it have to be Peugeot one
Andy206
PostPosted: Sun Apr 27, 2014 2:12 am Up
£19.99 off fleabay..cheap and nasty but do the job Smile
PostPosted: Sun Apr 27, 2014 6:25 am Up
The light should eventually go off by itself once the engine ECU has seen enough drive cycles without a fault.
The fault codes will still be stored in the engine ECU memory though.
ash5
PostPosted: Sun Apr 27, 2014 11:38 am Up
I will buy a cheap as chips one of eBay tonight then if that's all I need
VorTechS
PostPosted: Sun Apr 27, 2014 1:31 pm Up
Staff - Vortechs
You need to be careful. Not all code readers can clear the codes!
PostPosted: Sun Apr 27, 2014 1:40 pm Up
Get an ELM-327 lead or bluetooth E-OBD connector You can then download different software for either laptop or smartphone.
This is presuming your car is E-OBD compliant (2001 onwards for petrol and 2004 onwards for diesel). Some software will work with earlier models though, since OBD-II became mandatory in the US in 1996 and manufacturers fitted it to all builds rather than building a specific system for a single market.
