Latest: tebas93089
Overall: 17179
Online Now [55]:
Visitors: 54
Today: 17702
Total: 138119658
Forums › The Car › 206 Problems › need help!antipollution
chefboy1985
PostPosted: Sat May 03, 2014 12:21 pm Up
Just fitted my manifold on to my 206 gti but the engine management light is on sayin anti-pollution fault is this a comment fault is so how to I fix it?
PostPosted: Sat May 03, 2014 12:29 pm Up
Need's scanning to see what fault codes are now stored.
I take it there are no air leaks on the manifold, the lambda sensor isn't damaged & is plugged in?
19Connor92
PostPosted: Sat May 03, 2014 1:03 pm Up
exhaust or inlet manifold
chefboy1985
PostPosted: Sat May 03, 2014 1:14 pm Up
Both lambdas are plugged in,but the cat is out? It's the exhaust mani I chsnged
19Connor92
PostPosted: Sat May 03, 2014 2:07 pm Up
And you have decat? If not y is the cat out? anti pollution can be caused be lambda, bad fuel, cat, throttle body gasket can some times attribute to the fault code.
chefboy1985
PostPosted: Sat May 03, 2014 2:21 pm Up
Yeh I decated it,and y not more power better flow?is it that that is causing it?
PostPosted: Sat May 03, 2014 3:05 pm Up
The second lambda sensor is there to detect the amount of oxygen present. And since its seeing naff all it will throw up the code P0420 catalytic convetor efficiency (ie your cats f****d is what is trying to say)
You need a lambda sensor extender (found on ebay, i recommend the 90 degree ones) so it is removed from the main stream of exhaust gases and tells the ECU the cat is working fine
19Connor92
PostPosted: Sat May 03, 2014 3:09 pm Up
What he said.
chefboy1985
PostPosted: Sat May 03, 2014 3:49 pm Up
That's great addaz thanks very much for your help,is it quite straight forward to fit?and do I need to have the code cleared once it's fitted?
