Posted: Sun May 04, 2014 11:21 am |
hi just bought a wee 206 the run around in looking for info or prices on the advisory items section as I dont understand them. 1 offside track rod end ball joint has slight play. 2 nearside front lower suspension arm rubber bush deteriorated but not resulting in excessive movement. 3 nearside rear suspension arm synthetic bush deteriorated no excessive movement. 4 offside rear suspension arm bush deteriorated but not resulting in excessive movement. 5 advise all pipes on vehicle brake pipe slightly corroded. 6 advise age related corrosion on underside and outer sills of vehicle. any info would be great thanks
Posted: Sun May 04, 2014 12:48 pm |
Trade Rating: +13
1, track rod end needs replacing
2, wishbone needs replacing
3+4, rear beam is almost shoot
5, brake pipes are corroded
6, surface rust is setting in.
Posted: Sun May 04, 2014 1:37 pm |
so will it be expensive to repair then?
Posted: Sun May 04, 2014 1:39 pm |
A rear axle will set you back £250-300 depending on how you do it, it would be more if you get a reconditioned one.
Posted: Sun May 04, 2014 2:04 pm |
ok thanks
Posted: Sun May 04, 2014 2:05 pm |
Trade Rating: +13
Posted: Sun May 04, 2014 2:10 pm |
| iainlovatt wrote: |
| A rear axle will set you back £250-300 depending on how you do it, it would be more if you get a reconditioned one. |
Shocked you haven't got one for sale
