Online Now [770]:
Visitors: 769
Today: 112350
Total: 145222625
Forums › Welcome › Frequently Asked Questions (FAQ) › 2 common problems
2 common problems
Forum Index › Frequently Asked Questions (FAQ)
tommyboy1289
PostPosted: Sun Apr 27, 2014 1:32 pm Up
Hi again guys
Right so i've got the airbag light on, my car had a small bump before I bought it, from what I can gather chances are it's the ECU, I've looked under the seats and can't see the connectors, and I wouldn't know what to check with the pretensioners. For £9.95 is it worth sticking a replacement ECU in (exactly the same numbers) to see if it cures it.
Also the anti pollution fault keeps displaying, stuck my OBD-II meter on and it's saying P0135 - O2 sensor heater circuit (Bank 1 Sensor 1). For £13 delivered again would you chance changing the lambda on the exhaust manifold?
Thanks in advance everyone Smile
ukskater01
PostPosted: Sun Apr 27, 2014 5:09 pm Up
Get a garage to read the codes properly. Then you will know exactly why your getting the faults and start fixing the faults properly.
