Posted: Tue Apr 29, 2014 1:17 pm |
Posted: Tue Apr 29, 2014 2:56 pm |
I'm guessing that valve it your low pressure valve, you will need to get your mechanic to de gas the air con, unscrew the valve and screw it a new one. Then regass, he shouldn't of regass ex the air on without replacing the valve as he knows your not suppose to let the gas out into he atmosphere
| You never really learn to swear until you learn to drive | |
Posted: Wed Apr 30, 2014 2:29 pm |
Well every A/C system got 2 points (High & Low) or (Hot & Cold),and in your case this is the Hot or high one,that guy should of replaced this valve before he recharge the system with gas,or he could of checked it with air without A/C gas ,then tell you that you got a problem,so that you can fix it.
Posted: Wed Apr 30, 2014 4:41 pm |
ok thats fine
so can I change just the valve? which ref. is it?
Posted: Sun May 11, 2014 1:49 pm |
anybody knows the reference number for that part?
thanks
Posted: Mon May 12, 2014 1:39 am |
Just phone the dealership and tell them what you need. Believe it or not the dealers aren't as expensive as some people make out
