Latest: Beduff1977
Overall: 17134
Online Now [1201]:
Visitors: 1200
Today: 256913
Total: 110111082
Forums › The Car › 206 Problems › Running problems.
Running problems.
Rob-206
PostPosted: Thu May 03, 2012 11:15 am Up
Hi,I have a 1.1 206 on a 51reg I currently have a problem with it I hope someone can help.
About 2 weeks ago I was on my way to work and as I pulled up I felt the car missfire alitte anyway this got worse on the way home along with constant cutting out at traffic lights!.
I was told it was the map sensor so I went and bought a new one last sunday and fitted it,all was fine till today and it's doing the same thing again now!,I've just tryed another idle control valve to see if that would sort it but it's still the same.It's not brought the engine management light on and there aren't any fault class in the e.c.u......so I'm at a lost.
Any help would be much appreciated.
Rob-206
PostPosted: Fri May 04, 2012 9:35 am Up
Items changed so far are....map sensor,throttle position sensor,idle control valve,both lambda sensors,plugs,coil pack,and engine temp sponsor.
Any ideas???.
richpowell91
PostPosted: Fri May 04, 2012 12:14 pm Up
Have you tested your injectors? When mine have gone before they didn't bring the engine management light on and no codes were shown.
Rob-206
PostPosted: Sat May 05, 2012 7:58 am Up
Changed them anyway,all sorted now though.
Rob.
NJ86
PostPosted: Tue Apr 08, 2014 4:46 pm Up
How did you sort it as I'm having the same trouble. Car cuts out when slowing down for corners and roundabouts.....
PostPosted: Mon Apr 14, 2014 5:44 pm Up
NJ86. What model is your car, capacity, diesel, petrol 8 or 16V?
206Info_SW_Scots
PostPosted: Wed Apr 16, 2014 10:31 am Up
So what was the problem and what fixed it ?
Answering this will help others solve a similar problem, maybe.
206 SW 55 Plate - Happy Owner
Lollyfist
PostPosted: Sat May 17, 2014 12:02 pm Up
lol that's frustrating, was there ever an answer to what was changed that solved this? Having the problem myself, not spent very much on it yet, but would like it fixed.
Lollyfist
PostPosted: Sat May 17, 2014 12:03 pm Up
Oh by the way, I've got an '03 2l 206 cc. I love it, I really don't want to have to get rid of it.
