Latest: Puggingalong
Overall: 17129
Online Now [162]:
Visitors: 161
Today: 60906
Total: 101100733
Forums › The Car › 206 Talk › What should i do?
What should i do?
g3dd35
PostPosted: Sat May 17, 2014 4:21 am Up
Hi I have a bit of a problem I have a pair of 206 gti's one is a standard gti and the other is a gran tourismo (gt number 1101)
The problem I have is what one to keep and what one to break.
The gt has a seized engine. The gti has a sweet running engine
The gti has a seized rear axel. The gt's axel is fine.
The gt has been modified. The gti is completely standard
Gti has 100odd k the gti has under a 100k
The gt is a V plate the gti is a 2003
Ok ok you lot probably get the point my questions are --
Is the gt worth doing more work to just to save a gt?
PostPosted: Sat May 17, 2014 5:22 am Up
Swap the axle from the GT to the Gti. Easier than swapping the engine.
Break the GT and any parts you want to keep, just swap them onto the GTi
g3dd35
PostPosted: Sat May 17, 2014 6:01 am Up
That was my initial plan, I just wasn't sure if I would be breaking a rare car and getting sent to hell for it lol Very Happy
PostPosted: Sat May 17, 2014 10:47 am Up
Nobody really cares about the GT. its not really special enough.
PostPosted: Sat May 17, 2014 10:52 am Up
Send them both of to China to be recycled in to something more decent.
