Online Now [315]:
Visitors: 315
Today: 64699
Total: 142447495
Forums › The Car › 206 Problems › 206 gti (138) brakes
Pugnutter
PostPosted: Sun May 18, 2014 11:32 am Up
evening all,
im after some advise both rear calipers are seized on my car, so i am thinking of upgrading them along with the fronts so my question is what would be a good upgrade that will bolt straight on?
many thanks chris
PostPosted: Sun May 18, 2014 1:15 pm Up
No point upgrading rear calipers.
usher
PostPosted: Sun May 18, 2014 1:23 pm Up
The front you can change the calipers to 180 ones with180 discs and aagain 20mm in disc size but the rears you can't easily
Tbh my gti would have been fine on the track with std set up just with alot better pads and discs so for road use I would stay the same performance wise and get some better discs and pads
If you are after looks then 406 brembo calipers with gti 180 discs are good but you will have a lot more travel on the pedal also they squeal
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Pugnutter
PostPosted: Sun May 18, 2014 3:54 pm Up
Nice one cheers guys, so stick with standard and just upgrade pads and disc's?
usher
PostPosted: Mon May 19, 2014 12:32 pm Up
im going with ferodo pads and mtec discs, macj is running brembo discs and brembo pads iirc on his rally car with no issues
project thread WIP
garage
FAQ
206 gti firedance
