Latest: tbafonso
Overall: 17130
Online Now [298]:
Visitors: 297
Today: 42845
Total: 103628645
Forums › The Car › 206 Problems › hi all from mark in north east
cptstoner
PostPosted: Wed May 21, 2014 6:13 am Up
Having probably with overheating,and no blowers. Radiator popped so i replaced it aswell as the radiator fan swich. Still over heating and cutting out. Can any 1 help
RichardEke
PostPosted: Wed May 21, 2014 12:14 pm Up
Hello there and welcome to the site.
If you use the search function you'll find what you're looking for.
But from previous threads the front relay/fan wiring is the most likely suspect, they corrode then fail unfortunatly.
EDIT: Sorry miss understood the blowers bit, sound like you've got air in the system, look in the How-to section Timon did a guide on how to bleed the cooling system.
Regards, Richard.
Barking
PostPosted: Wed May 21, 2014 1:03 pm Up
Hi Mark Waving o/
Welcome to 206info.co.uk
Enjoy your stay Thumb Up
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Wed May 21, 2014 1:05 pm Up
No blowers as in the cabin fan doesn't work on any speed?
Did you bleed the system when you changed the radiator?
Does the cooling fan come on at all?
Thread moved to 206 problems
PostPosted: Wed May 21, 2014 1:37 pm Up
Stuck thermostat? Does the top hose get too hot to hold or stay relatively cool.
LiamMiller
PostPosted: Thu May 22, 2014 4:53 am Up
Hi Mark welcome
Where in the North East do you come from. (It's where I'm from too)
cptstoner
PostPosted: Wed Aug 13, 2014 2:27 am Up
Thanks to all, this helped lots. The main issue was that i hadnt bled the system when i changed the rad, all tho i still have any internal blowers at all. And iv found that i need to replace the piston rings as my air filter box is looking shockingly full of oil. Once again thanks all for getting back to me and helping sort my problem.
