Latest: Stu-mill
Overall: 17131
Online Now [61]:
Visitors: 60
Today: 7818
Total: 104917458
Forums › The Car › 206 Problems › Stripped bolt on the rear axle and drum to disc conversion
RationalInsanity
PostPosted: Sun Jun 01, 2014 3:01 pm Up
A little while ago I noticed that my cars ride height was a bit lop sided (About 1/2" lower on the drivers side), after doing some research I seem to be looking at a buggered up lowering job. So I thought, screw it, lets see if I can do a better job. I found and followed Ape's lowering guide, although I didn't get far. Drivers side the first bolt came off fine, move over to the passengers side, some b*****d stripped the damn bolt, no chance of any grip at all.
I've talked to a few garages and all of them have shunned me making a gagging noise when I tell them it's a Peugeot :/ even though I just need a bolt taken out.
So I was wondering what the best way to get this bolt out is. I don't need to replace the bolt because I want to convert the drums to discs which I've been recommended to replace the whole axle(?) so the torsion bar gets upgraded to a GTI one as well.
If anyone could give me some guidance to both getting the bolt out and doing the conversion that would be extremely helpful and I would be eternally grateful!
~Rational
Seatock789
PostPosted: Sun Jun 01, 2014 3:57 pm Up
Should be an easy job for a garage, I think they are just being lazy.
There are a number of methods I use:-
1> Use a flat bladed screwdriver and hammer it into the bolt so it creates a slot and you can turn it, the hammer effect sometimes frees the bolt.
2> Use a hacksaw / grinder to cut a slot so you can use a screwdriver on it.
3> Hack / Grind it off if possible
4> Weld a 2nd nut onto it
5> Drill it out, go up in drill sizes starting with the smallest 1st
Hope 1 of the above methods work.
RationalInsanity
PostPosted: Sun Jun 01, 2014 4:22 pm Up
Thanks for the info! I also thought it would be easy for a garage, but oh well I guess I'll just do it myself if I need to, but after having a look it seems that if I did the disc brake conversion and replaced the rear axle I won't need to get that bolt out. I might be very, very wrong though...
But thanks again for the advice!
PostPosted: Mon Jun 02, 2014 1:25 am Up
I hit mine with a sharp wood working chisel. It cut into the head nicely and turned the bolt. Mine weren't the originals though.
