![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › gti137 Head skim advice, and head rebuild tips |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Mon Jun 02, 2014 10:29 am |
Hi
Have the early gti engine on a W plate. Just taking the head off to change the valves (coolant froze in winter, my fault). Going smoothly so far, no troublesome bolts etc
I've done the job on 4 other cars before but never needed a skim. However, will get this head skimmed even if it is arrow straight . What's the likely cost of a skim, anything to look out for when choosing a place to do it?
Any other things I should do to this head whilst rebuilding it? Do they respond well to any smoothing and porting?
Also, do I need the correct timing pins on reassembly or will suitable drill bits do?
Cheers, DB
| | ![](images/spacer.gif) |
Posted: Mon Jun 02, 2014 10:41 am |
Trade Rating: +13
My head skim for 1.4 16v was £60.
Posted: Mon Jun 02, 2014 11:49 am |
The coolant froze? So what damage did it do? No cracked block?
I'd buy some new O rings for where the metal coolant pipe slots into the water pump housing and thermostat block.
Posted: Mon Jun 02, 2014 1:27 pm |
When I changed my 106 headgaskett all I did was rub the block with some sandpaper and a block did the trick but it was only a 1ltr
Posted: Mon Jun 02, 2014 2:48 pm |
Sgould be fine, its not the same as an overheating headgasket fail. Although you can never be sure of the problems you cant see.
| ![](themes/base/images/forums/otr.gif) |
