Latest: Puggingalong
Overall: 17129
Online Now [339]:
Visitors: 338
Today: 74047
Total: 101281189
Forums › The Car › 206 Problems › melted ecu pins
melted ecu pins
pumba
PostPosted: Thu Jun 05, 2014 5:28 pm Up
hi guy`s do anyone know what pins 4 l and 4 m are in the middle ecu plug?. also can the ecu be changed or will it be a case of swaping ecu bsi an key.
these pins seem to have burnt/melted a bit in the ecu and plug, so im looking to try and find the cause and best way to solve this issue any help greatly appreciated
PUMB@206
pumba
PostPosted: Thu Jun 05, 2014 7:00 pm Up
forgot to say the car is a 206 gti 2000 reg preplex
PUMB@206
PostPosted: Fri Jun 06, 2014 1:55 am Up
Photos are required. You need to also fix the reason why this happened
copey
PostPosted: Fri Jun 06, 2014 6:40 am Up
possibly something bba reman could do?
02 2.0 hdi d turbo
pumba
PostPosted: Fri Jun 06, 2014 12:25 pm Up
Hi thanks guys, well the car was running fine an i only noticed this whilst fitting it to my car so hopefully its no major damage done.my mate checked out the pin numbers with his diagrams so its sorted the middle plug pins are to do with the earth circuit an the one pin in both the end plugs are to do with high resistance in the injector circuit so I will sort theses issuses once I finished the conversion thanks a lot tho guys
PUMB@206
