Latest: SA01
Overall: 17138
Online Now [1201]:
Visitors: 1200
Today: 432251
Total: 111746467
Forums › The Car › 206 Problems › Coolant / Fan issues - PLEASE HELP :\
Go to page Previous  1, 2
PostPosted: Sat Jun 07, 2014 2:54 pm Up
Well since you took the plug of the temp. sensor off,and fans didn't kick in,then the problem is in the fan itself,or the wiring leading to it,or the relays,but with age of your car,i would say the wires heading to the fan is bad,which explains the Perm. Fault you had for the fan,it's can be fixed easily,and I don't recommend fitting an electric fan instead of the original one.
And since u have the A/C off your car,I suggest that you take it off the BSI setting as well,so that the system don't recognize it anymore.
SinfulDesignCom
PostPosted: Sat Jun 07, 2014 6:49 pm Up
Thanks Timon...
This is what I was wondering how to accomplish - and whether it would be having an effect on the fan operation. The car might be 11 years old, but only 40k and garaged overnight, I would hope the wiring is ok. If you can inform me of the process to remove the A/C from the BSI I would be grateful?
I have tested the relays - which I assume are those behind the little black panel next to the fan itself - slow and fast speed?? This would then lead me to the wiring as you suggest.
Engines I can deal with, but electrics are lost on me outside of a car stereo... Neutral
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
PostPosted: Mon Jun 09, 2014 3:16 pm Up
You are welcome,I will try to get u a detailed steps on how to remove the A/C from the BSI,,..check the plugs and see if any damage done there.
SinfulDesignCom
PostPosted: Mon Jun 09, 2014 3:24 pm Up
Many thanks - is appreciated.
Will keep the forum updated of findings
SinfulDesignCom
PostPosted: Fri Jun 13, 2014 3:38 pm Up
Right, tracked down a dodgy wire after all this, and have now re-wired.
Issue now is that it is STILL not working - however, is this due to the fact that I haven't cleared the faults? Thus clearing them will cure?
As luck would have it, my diag laptop is on the blink. So frustrating Neutral
SinfulDesignCom
PostPosted: Sat Jun 14, 2014 5:57 pm Up
UPDATE: Cleared the faults and still the issue.
I have run the car to temperature again and the short circuit fault on the relay comes back. I have found that there is a +ve feed going to what should be the switched negative side of the relay... of about +2.4v.
I assume this feed travels back to the ECU somewhere and it is meant to ground to switch the relay, but I am at a loss on this one. If anyone can help, or at the least tell me what reading they are getting from the fan relay, it would be bloody helpful..
Cheers
Deano
PostPosted: Mon Jun 16, 2014 3:49 pm Up
What is a +'ve and how do u bypass the resistor ed cheers mate and how do u test resistor
Deano
PostPosted: Mon Jun 16, 2014 4:44 pm Up
I know on old cars u could put a split pin in the plug and the fan would work all the time can u do it on theses if so which plug is it ? Thank lads info much appreciated don't mean to forum jump but our problem might be the same things cheers lads
SinfulDesignCom
PostPosted: Mon Jun 16, 2014 5:37 pm Up
+ve is shorthand for "positive". You can bridge the pins of the fast speed fan either side of the relay coil, but it is not a good idea. I had planned on modifying the setup anyway as the fan cuts in way too late for track use. Unfortunately, the 206 coolant temp sensor works on resistance so it can pass the readings to the gauge, so you cannot replace it with a simple switch as the gauge wouldn't work. My answer is to put a separate sensor into the top hose with a switch operating at a cooler temperature. That way you don't need to worry about ECUs failing due to air con etc., the fan will just work, and if it fails, you have a very simple circuit to test to diagnose.
Last edited by SinfulDesignCom on Mon Jun 16, 2014 8:50 pm; edited 1 time in total
RichardEke
PostPosted: Mon Jun 16, 2014 5:45 pm Up
Evening,
When i purchased a new one from Peugeot its resistance was 0.8 - 1 ohm, when measuring across the coil.
The broken one i took off had no continuity and therefore infinate resistance.
Regards, Richard.
Deano
PostPosted: Wed Jun 18, 2014 3:24 pm Up
At least your fan kicks in mine doesn't at all would go in red if I didn't use heaters in traffic but it a killer
Page 2 of 2
