Online Now [1000]:
Visitors: 999
Today: 154751
Total: 146299556
Forums › The Car › 206 Problems › New but continued problem? Video added
Tolkienfan001
PostPosted: Wed Jun 04, 2014 1:41 am Up
Trade Rating: +13
So had the new alternator fitted and now the issue at hot idle is worse.
With electrics on and car idling at 90c the aircon and mfd display flicker the revs then drop the ECU flicks the throttle. All goes back to normal. Then does it over and over again.
Any ideas?
Still no stored codes. No issues at cold idle and battery tested as good.
2005 1.4 16v Sport
Check out my 206 here!
Tolkienfan001
PostPosted: Wed Jun 04, 2014 7:30 am Up
Trade Rating: +13
Video added
2005 1.4 16v Sport
PostPosted: Wed Jun 04, 2014 2:37 pm Up
What throttle body you got? if it's a drive by cable,then you need to replace your TPS,as when it goes hot,and fans kicks in,you will have the load,which makes u hear a sound of click in the BSI area,as the car is going to stall but it don't.
if your car got a fly by wire throttle,try to reset it,using the PP2000.
Cheers,
Tim
Tolkienfan001
PostPosted: Wed Jun 04, 2014 2:56 pm Up
Trade Rating: +13
It's fly by wire. I don't have pp2000. Sad just waiting on hawkers from Norwich to get back to me about using his....
How do you reset it?
2005 1.4 16v Sport
PostPosted: Sat Jun 07, 2014 3:30 pm Up
When you get the PP2000,I will tell you in details Smile
