Online Now [565]:
Visitors: 564
Today: 31191
Total: 105170391
Forums › The Car › 206 Problems › Starter Motor Replacement
alborough1974
PostPosted: Sun Jun 08, 2014 2:15 am Up
Ok i had my starter motor fail on friday. Have done various checks to confirm that is the fault power is definetly reaching the starter when ignition key turned to start and 12v is also on the main feed from the battery however looking at the starter access is not going to be easy due to fuel injection system etc in the way from above and a cross member below so i'm now wondering if its possible to replace the starter without removing have of the injector sytem etc or if it can be done without.
Access is certainly not looking good but i don't want to remove anymore than i need to the car is a 2002 206SW 1.4
2002 Peugeot 206 1.4 XT SW
PostPosted: Sun Jun 08, 2014 6:08 am Up
Pull the battery box out 4 10mm bolts and possibly the air intake pipe from the airbox and you'll have all the access you'll need.
PostPosted: Sun Jun 08, 2014 6:22 am Up
Access is pretty good on the TU3 due to the stone age mid 1980's design of the engine, there are plenty of worse more modern cars out there to try & work on.
