Forums › The Car › 206 Talk › GTI 4 into 2 Exhaust Manifold |
Posted: Fri Jun 13, 2014 1:02 pm |
not bad.. i wish i could buy that
Posted: Fri Jun 13, 2014 3:25 pm |
I wouldn't touch that manifold. Doesn't look the right dimensions and it's not equal length either.
Posted: Fri Jun 13, 2014 5:53 pm |
| Edward wrote: |
| I wouldn't touch that manifold. Doesn't look the right dimensions and it's not equal length either. |
Good advice.
