Latest: lio94
Overall: 17181
Online Now [144]:
Visitors: 143
Today: 108509
Total: 140585496
Forums › The Car › 206 Problems › 206 cylinder head gasket needs replacing.
duopkik
PostPosted: Tue Jul 08, 2014 7:54 am Up
After taking my car to the garage this morning for a service, they rang back later to say that the cylinder head gasket needs replacing. The car is a 1.4 from 2003 and has only done 45,000 miles. They haven't charged me which was good of them but at £450 it seems a little steep.
My friend says that it will need the head skimmed and valves re-seated and will also need a new belt and tensioner as well if replacing the head gasket.
Does this all sound ok?
richpowell91
PostPosted: Tue Jul 08, 2014 1:26 pm Up
If there going to send it away to be pressure tested and skimmed then expect that to be about £60-£100 of the cost.
The book time is about 6 hours if the above is true. Otherwise its a 4 hour job.
By the time you have a new cambelt kit and water pump, manifold gakets, oil and filter. Anti freeze, headgasket, headbolts it all adds up.
Whats the garages hourly labour rate?
PostPosted: Wed Jul 09, 2014 12:54 am Up
What reason does it need to be changed? If its oil it will only need a clean or skim
