Latest: tbafonso
Overall: 17130
Online Now [174]:
Visitors: 172
Members: 1
Today: 13889
Total: 103257921
Forums › The Car › 206 Problems › Running vey hot not overheating much
coolhas
PostPosted: Fri Jun 20, 2014 4:16 pm Up
Hi all I can't for the life of me understand what's happening with my 206 1.4 it is running extremely hot but never reaches the red while driving but almost hits the red when I turn the ignition on and back off. while driving it's always back and forth between 90 and 100 But extermely hot under bonnet the gathers can't seem to understand. Me but it's running too hot and overheats after long drive when restarted work already done is head gasket ,water pump ,thermostat full flush many times oil change I would really appreciate some insightful help
usher
PostPosted: Fri Jun 20, 2014 4:50 pm Up
between 90 and 100 is normal running temp
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
RichardEke
PostPosted: Sun Jun 22, 2014 3:24 am Up
Morning,
Is the heater cold sometimes? I ask because if it were me i'd bleed the cooling system to get rid of sir locks.
Timon wrote a guide here: www.206info.co.uk/Foru...56271.html
Might also be worth checking that there isn't any leaves or something blocking the radiator.
Regards, Richard.
Life would be easier with universal jointed arms and fingers sometimes
bodieanddoyle
PostPosted: Sun Jun 22, 2014 11:36 am Up
Blocked radiator symptoms are usually its fine up to a certain point but the faster you go the hotter it gets. The on/off scenario could be a clue. It can't get much hotter when its not running. I'd get the radiator checked and bleed it up.
drives a little green deep fat fryer. 1.4 hdi sw.
coolhas
PostPosted: Sun Jun 22, 2014 5:59 pm Up
Everything is working properly on my car, cooling system, fans, switches, the lot.
However - the heat transfer into the cabin on a really hot day is starting to wear a little thin. I am also not too happy about cooking everything under the bonnet to death which can only lead to other problems.
Has anyone done anything to reduce under bonnet temperatures that has made a significant difference. Like I said the engine is not overheating while driving so I am not talking about fan mods, I am looking for other ideas/suggestions.
DREWDEN
PostPosted: Tue Jun 24, 2014 2:22 pm Up
If its getting realy very hot under the bonnet, and you say the engines not overheating, and the cooling system is working properly, please tell me where the heats coming from, realy would like to know.
206 2ltr Hdi glx 53 plate
PostPosted: Tue Jun 24, 2014 4:08 pm Up
Any engine will be hot, even in the winter? Don't see what your getting at if nothing wrong.
Where do you live? Do you have air con.
