Latest: Beduff1977
Overall: 17134
Online Now [588]:
Visitors: 587
Today: 201349
Total: 107602922
Forums › The Car › 206 Problems › Electric Window Problem.
buseng
PostPosted: Sun Jun 22, 2014 6:04 am Up
I have a 55plate 206 SE, 1.4 Petrol 8V, 5dr hatchback.
For a while I have had my rear electric windows isolated on the dash switch.
However during this hot weather I have decided to use them & turned them on. At first they both worked but after a short while the O/S/R stopped working, it stopped once & started again but now has stopped altogether. Luckily it is almost in the fully closed position. When you operate the switch you cannot hear any clicking unlike the other ones.
Could it be a relay? Also does anyone know where the rear window relays are on this car? I have found them on servicebox but the positions aren't clear. I hope it isn't the actual regulator itself.
Thanks in advance.
PostPosted: Sun Jun 22, 2014 6:17 am Up
If ones working and one isn't then I think you could disregard the relay.
I'd be more inclined to look at the switch, motor and wiring for the O/S/R
PostPosted: Sun Jun 22, 2014 6:21 am Up
Give both switches for the window in question a good prodding, if one switch is faulty it will stop the window working due to the way the circuit is wired.
Motor might be stuck through lack of use, take the door panel of & give the window motor a firm smack or 2 with a small hammer while operating the window switches.
buseng
PostPosted: Sun Jun 22, 2014 3:11 pm Up
Thanks for the replies.
I may of sussed it, I unplugged the door loom from the centre pillar & plugged it back in giving it a wiggle. It seemed to work after that. I also gave the pins a quick spray with brake cleaner & WD40.
Will keep an eye on it.
