Latest: Stu-mill
Overall: 17131
Online Now [315]:
Visitors: 314
Today: 15858
Total: 104824722
Forums › The Car › 206 Problems › 2.0 Hdi metal pipe water leak...
HueyLions
PostPosted: Tue Jul 01, 2014 2:47 am Up
New to the Info exchange and needing a little help.
I have a 2001 2.0 Hdi D turbo for a couple of weeks now.
I'm guessing the previous owner has at some point put rad weld/similar into the car as lots of evidence of brown water on engine and bulkhead.
Yesterday the car began to dribble water almost as quick as I could fill it.
Upon inspection and removal of battery tray,air intake pipes and thermostat assembly I found a metal pipe at the rear of the engine has corroded.
This joins the thermostat assembly by means of a pushfit with a rubber o ring seal. I need to order one from my dealers....Any ideas what it's called/ what I should be asking for?
Thanks in advance
Huey
NOW SOLVED! Thanks Drewden for pointing me in the right direction.
