Forums › The Car › 206 Problems › New part from eBay - What's it called? |
Posted: Fri Jul 04, 2014 7:55 am |
Hi,
Might be a bit of a silly question but;
I need to find this part on ebay to connect my fog lights up, It's the connector that connects the fogs to the wires but I don't know what to type in or what it's called.
It kind of looks like this:
i.imgur.com/lgM2xRU.png
Thanks,
Dylan
Posted: Fri Jul 04, 2014 8:41 am |
Are you buying these because you want to install fogs? Or just replace the original ones for whatever reason?
If the former then these are already there as all 206's have the option for H4 and H7 conversions plus the fog connection.
Posted: Fri Jul 04, 2014 8:48 am |
Vexs wrote: |
If the former then these are already there as all 206's have the option for H4 and H7 conversions plus the fog connection. |
If this was the case, then Peugeot wouldn't sell H4-H7 adaptors that people can use when they change from frosted to crystals.
It depends on the year of build and which wiring loom was fitted at the build.
Not sure if this is the part you're after. Can't see them costing too much from the dealers
Posted: Fri Jul 04, 2014 9:53 am |
Yeah I think that is the one, the car already has fog lights but the cable has no connectors on the end.
Posted: Fri Jul 04, 2014 9:55 am |
The connector is a junior power timer plug.
