Latest: Beduff1977
Overall: 17134
Online Now [366]:
Visitors: 365
Today: 133398
Total: 109700014
Forums › The Car › 206 Talk › Driveshaft removal-O/S (driver side)?
Triggerfish
PostPosted: Sun Jul 06, 2014 1:14 pm Up
Anyone know how this is removed from the gearbox?
206: 1.1L, 2002.
iainlovatt
PostPosted: Mon Jul 07, 2014 6:37 am Up
Remove the rear engine mount and it should just pop out. Smile
(My Garage)
Triggerfish
PostPosted: Mon Jul 07, 2014 4:23 pm Up
That's a tough one.....to take the engine mount, 4 bolts at top and one lower.....guess the engine would need to be supported temporary under the oil pan?
Decided to go the other way, the drive shaft bearings are held in by 2 no. eccentric screws (11mm), took these off and hammered from the gearbox side, through a gap just behind the bearings to force the shaft out.....tough one..!
206: 1.1L, 2002.
PostPosted: Tue Jul 08, 2014 11:05 am Up
That's actually the correct way of doing the job Wink
Triggerfish
PostPosted: Tue Jul 15, 2014 2:27 pm Up
So How do you actually put the new one back in?..as the bearings will be very tight against the surroundings. Surely you can't hammer it at the 2 no. eccentric screws locations so the actual bearings will fit through and enough into the slot so it has a good fit into the gearbox too?
Is there a special tool required for this? or do you actually just use the 2 no. eccentric screws to slowly guide and force the bearing into its place by turning the two 11 mm nuts?
206: 1.1L, 2002.
